Inleiding
The battery is the main power source of your device. After replacing your battery you should receive up-to 13 hours of battery life assuming normal usage.
Wat je nodig hebt
Remove the back cover.
Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
Remove any black tape from the device.
Keep the tape, you will need to put it back on when you are done.
Unscrew the battery from the device.
The device has 5 screws to remove, keep the screws.
4 andere personen hebben deze handleiding voltooid.
