Ga door naar hoofdinhoud
Toshiba Equium M70 Faulty Graphics
Wat je nodig hebt
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: stap 1, afbeelding 1 van 1
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: stap 2, afbeelding 1 van 1
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: stap 3, afbeelding 1 van 1
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: stap 4, afbeelding 1 van 1
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: stap 5, afbeelding 1 van 1
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: stap 6, afbeelding 1 van 1
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: stap 7, afbeelding 1 van 1
    • This is the CPU with the new alloy shim fitted.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Terry Sim
207 Reputatie
1 Handleiding geschreven
Één opmerking
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 2,050
