Ga door naar hoofdinhoud
Toshiba Encore Mini Screen Replacement
Wat je nodig hebt
  1. Toshiba Encore Mini Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Encore Mini Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Screen Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Screen Replacement: stap 4, afbeelding 1 van 2 Toshiba Encore Mini Screen Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Screen Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Screen Replacement, Screen: stap 6, afbeelding 1 van 3 Toshiba Encore Mini Screen Replacement, Screen: stap 6, afbeelding 2 van 3 Toshiba Encore Mini Screen Replacement, Screen: stap 6, afbeelding 3 van 3
    Koop
    • The audio module must be removed to replace the screen.
    • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
    • Gently remove red/black wire strands from the clips holding them to the back of the screen.
  7. Toshiba Encore Mini Screen Replacement: stap 7, afbeelding 1 van 2 Toshiba Encore Mini Screen Replacement: stap 7, afbeelding 2 van 2
    • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
    • Adhesive on the bottom of the speaker module may make it difficult to remove.
    • Set the audio module and attached wire aside.
  8. Toshiba Encore Mini Screen Replacement: stap 8, afbeelding 1 van 3 Toshiba Encore Mini Screen Replacement: stap 8, afbeelding 2 van 3 Toshiba Encore Mini Screen Replacement: stap 8, afbeelding 3 van 3
    • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange/gold ribbon in place. (It is approximately 1/4" wide.)
    • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
  9. Toshiba Encore Mini Screen Replacement: stap 9, afbeelding 1 van 2 Toshiba Encore Mini Screen Replacement: stap 9, afbeelding 2 van 2
    • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
    • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
  10. Toshiba Encore Mini Screen Replacement: stap 10, afbeelding 1 van 3 Toshiba Encore Mini Screen Replacement: stap 10, afbeelding 2 van 3 Toshiba Encore Mini Screen Replacement: stap 10, afbeelding 3 van 3
    • Damaging this ribbon will permanently disable your device!
    • Using needle-nose tweezers, carefully flip up the dark gray cover.
    • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
  11. Toshiba Encore Mini Screen Replacement: stap 11, afbeelding 1 van 3 Toshiba Encore Mini Screen Replacement: stap 11, afbeelding 2 van 3 Toshiba Encore Mini Screen Replacement: stap 11, afbeelding 3 van 3
    • Using a Phillips 000 screwdriver, remove the screws holding components together.
    • Remove four 4.2 mm Phillips screws
    • Remove one 3 mm Phillips screw
  12. Toshiba Encore Mini Screen Replacement: stap 12, afbeelding 1 van 2 Toshiba Encore Mini Screen Replacement: stap 12, afbeelding 2 van 2
    • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
    • The motherboard may resist as you try to lift it --this is normal.
  13. Toshiba Encore Mini Screen Replacement: stap 13, afbeelding 1 van 1
    • Now that your screen is detached from the rest of the device components, it is ready to be replaced.
Conclusie
Christine co
131 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-3, Liner SU 2015 Lid van UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Leden
6 handleidingen geschreven
Één opmerking
What is the small orange/gold ribbon in step 8 used for? I'm assuming that it's what registers touches on the screen because my tablet isn't reading my touches. I ask this because the dark grey bar on my tablet has been broken off, so there's nothing to hold the ribbon in place, and I can't do anything on my tablet because it won't respond to me touching it.
Gregory Banks - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,513
