Inleiding
The following guide gives instructions on how to remove the motherboard. This procedure is done in order to replace multiple components. Be sure to avoid damaging any components or connectors removed from the motherboard. It is advised to back up data to an external device before attempting any component replacement.
Wat je nodig hebt
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
Gently remove red/black wire strands from the clips holding them to the back of the screen.
Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
Remove yellow tape.
Use tweezers to pull on the camera housing until it is free of the motherboard.
