Ga door naar hoofdinhoud
Toshiba Encore 2 WT10-A Battery Replacement
Wat je nodig hebt
  1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Battery Replacement: stap 2, afbeelding 1 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 2, afbeelding 2 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Battery Replacement: stap 3, afbeelding 1 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 3, afbeelding 2 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 3, afbeelding 3 van 3
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Battery Replacement: stap 4, afbeelding 1 van 2 Toshiba Encore 2 WT10-A Battery Replacement: stap 4, afbeelding 2 van 2
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Battery Replacement: stap 5, afbeelding 1 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 5, afbeelding 2 van 3 Toshiba Encore 2 WT10-A Battery Replacement: stap 5, afbeelding 3 van 3
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Battery Replacement: stap 6, afbeelding 1 van 2 Toshiba Encore 2 WT10-A Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the battery from the compartment.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,657
