Ga door naar hoofdinhoud
Toshiba Dynabook AX 53D Memory Replacement
Wat je nodig hebt
  1. Toshiba Dynabook AX 53D Memory Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Memory Replacement: stap 2, afbeelding 1 van 1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Memory Replacement, Memory: stap 3, afbeelding 1 van 1
    • Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
  4. Toshiba Dynabook AX 53D Memory Replacement: stap 4, afbeelding 1 van 1
    • Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
  5. Toshiba Dynabook AX 53D Memory Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the chip out of the clips.
    • Touching the contacts or the chips on the board could destroy the components.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher
525 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G7, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G7
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 387
