Ga door naar hoofdinhoud
Toshiba Dynabook AX 53D Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Dynabook AX 53D Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Start by using the #J1 screw bit to unscrew the the two 4.6 mm hard drive bay screws located on the underside of the laptop. They are located next to the Windows license sticker.
  4. Toshiba Dynabook AX 53D Hard Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Dynabook AX 53D Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Gently pull horizontally on the clear plastic tag to unplug the hard drive.
    • Make sure not to touch the circuit board or connectors on the drive as that may damage them.
  5. Toshiba Dynabook AX 53D Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • The drive can now be removed from the metal drive retainer by unscrewing the four exposed 4.1 mm #J1 screws on either side of the drive.
  6. Toshiba Dynabook AX 53D Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • The secondary hard drive can be removed following the same process on the right drive bay.
Conclusie
Christopher
510 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G7, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G7
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 1,023
