Ga door naar hoofdinhoud
Toshiba Chromebook CB35-A3120 Speakers Replacement
Wat je nodig hebt
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: stap 1, afbeelding 1 van 2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: stap 1, afbeelding 2 van 2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 2, afbeelding 1 van 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 3, afbeelding 1 van 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 3, afbeelding 2 van 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 4, afbeelding 1 van 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 4, afbeelding 2 van 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 4, afbeelding 3 van 3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 5, afbeelding 1 van 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: stap 5, afbeelding 2 van 2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
Conclusie
Jayce Houghton
176 Reputatie
1 Handleiding geschreven
USF Tampa, Team 15-6, Remmell Spring 2017 Lid van USF Tampa, Team 15-6, Remmell Spring 2017
USFT-REMMELL-S17S15G6
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 748
