Ga door naar hoofdinhoud
Toshiba Chromebook 2 Touchpad Replacement
Wat je nodig hebt
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Touchpad Replacement: stap 3, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 3, afbeelding 2 van 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Touchpad Replacement: stap 4, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 4, afbeelding 2 van 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: stap 6, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Touchpad Replacement: stap 7, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Touchpad Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: stap 9, afbeelding 1 van 1
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Touchpad Replacement: stap 10, afbeelding 1 van 3 Toshiba Chromebook 2 Touchpad Replacement: stap 10, afbeelding 2 van 3 Toshiba Chromebook 2 Touchpad Replacement: stap 10, afbeelding 3 van 3
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Touchpad Replacement: stap 11, afbeelding 1 van 1
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: stap 12, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: stap 12, afbeelding 2 van 2
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
  13. Toshiba Chromebook 2 Touchpad Replacement: stap 13, afbeelding 1 van 1
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
  14. Toshiba Chromebook 2 Touchpad Replacement: stap 14, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 14, afbeelding 2 van 2
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
  15. Toshiba Chromebook 2 Touchpad Replacement: stap 15, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 15, afbeelding 2 van 2
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
  16. Toshiba Chromebook 2 Touchpad Replacement: stap 16, afbeelding 1 van 3 Toshiba Chromebook 2 Touchpad Replacement: stap 16, afbeelding 2 van 3 Toshiba Chromebook 2 Touchpad Replacement: stap 16, afbeelding 3 van 3
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
  17. Toshiba Chromebook 2 Touchpad Replacement: stap 17, afbeelding 1 van 2 Toshiba Chromebook 2 Touchpad Replacement: stap 17, afbeelding 2 van 2
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Haley Hattendorf
598 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-4, Livingston Fall 2016 Lid van Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Leden
11 handleidingen geschreven
2 opmerkingen
Thanks for this guide! Worked perfectly.
Mathias Maes - Antwoord
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,844
