Ga door naar hoofdinhoud
Toshiba Canvio Connect V73600-C Disassembly
Wat je nodig hebt
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: stap 1, afbeelding 1 van 2 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: stap 1, afbeelding 2 van 2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: stap 2, afbeelding 1 van 1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: stap 3, afbeelding 1 van 1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: stap 4, afbeelding 1 van 1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: stap 5, afbeelding 1 van 1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: stap 6, afbeelding 1 van 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: stap 6, afbeelding 2 van 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: stap 6, afbeelding 3 van 3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Conclusie
CONVERSION
1.282 Reputatie
8 handleidingen geschreven
Australia Lid van Australia
Community
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 134
Altijd: 5,118
