Ga door naar hoofdinhoud
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
Wat je nodig hebt
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: stap 1, afbeelding 1 van 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 2, afbeelding 1 van 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 2, afbeelding 2 van 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 3, afbeelding 1 van 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 4, afbeelding 1 van 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 4, afbeelding 2 van 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: stap 5, afbeelding 1 van 1
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: stap 6, afbeelding 1 van 1
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 390
