Ga door naar hoofdinhoud
Toshiba A1304T Camera Replacement
Wat je nodig hebt
  1. Toshiba A1304T Camera Replacement, Back panel: stap 1, afbeelding 1 van 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Camera Replacement: stap 2, afbeelding 1 van 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Camera Replacement: stap 3, afbeelding 1 van 2 Toshiba A1304T Camera Replacement: stap 3, afbeelding 2 van 2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Camera Replacement, Camera: stap 4, afbeelding 1 van 2 Toshiba A1304T Camera Replacement, Camera: stap 4, afbeelding 2 van 2
    • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
    • Gently pull the silver plate from the phone using your fingers.
  5. Toshiba A1304T Camera Replacement: stap 5, afbeelding 1 van 3 Toshiba A1304T Camera Replacement: stap 5, afbeelding 2 van 3 Toshiba A1304T Camera Replacement: stap 5, afbeelding 3 van 3
    • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
    • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
Conclusie
Christopher
90 Reputatie
8 handleidingen geschreven
Cal Poly, Team 16-6, Maness Spring 2010 Lid van Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,056
