Ga door naar hoofdinhoud
Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement
Wat je nodig hebt
  1. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: stap 1, afbeelding 1 van 2 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: stap 1, afbeelding 2 van 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: stap 2, afbeelding 1 van 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing Screws: stap 3, afbeelding 1 van 1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing the Wheel: stap 4, afbeelding 1 van 1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Rear Wheel Suspension: stap 5, afbeelding 1 van 1
    • After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
  6. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: stap 6, afbeelding 1 van 1
    • Slide off the bottom part of the rod connected to the chassis.
  7. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: stap 7, afbeelding 1 van 3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: stap 7, afbeelding 2 van 3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: stap 7, afbeelding 3 van 3
    • Pull the black washer inside the spring downwards and towards the truck's rear simultaneously in order to remove the suspension.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Colton Sholtis
257 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-30, Amido Winter 2015 Lid van Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 200
