Inleiding
This guide shows how to remove and replace the right blade on the Toro Walk Behind Mower 21199HD 2018.
Wat je nodig hebt
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Tilt the mower onto its side so the blades are facing out.
Use an impact driver with a 5/8-inch socket to remove the right blade bolt.
