Inleiding
This guide shows how to remove and replace the control valve on the Toro Log Splitter 22618HD 2019 / LS-922.
Wat je nodig hebt
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Flip the red engine ON/OFF switch to the OFF position.
Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
Place a bucket underneath the device, below the control valve to catch any hydraulic fluid drips.
Use an adjustable wrench to loosen the nut securing the output hose to the L-fitting on top of the control valve.
Use an adjustable wrench to loosen the nut holding the input hose to the L-fitting on the bottom of the control valve.
Use an adjustable wrench to loosen the nut securing the top L-fitting to the control valve.
Use an adjustable wrench to loosen the nut securing the bottom L-fitting to the control valve.
Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the rear of the control valve.
Use an adjustable wrench to loosen the nut securing the control valve to the cylinder.
Use an adjustable wrench to loosen the nut securing the piston contraction fitting to the control valve.
Één andere persoon heeft deze handleiding voltooid.
