Inleiding
This guide shows how to remove the top cover of the Pentax MZ-S. Removing the top panel is often the starting point of more in depth repairs.
Wat je nodig hebt
Remove two 7.5 mm #00 screws.
Remove one 9.0 mm #00 screw.
Remove one 13.5 mm #00 screw from inside the battery compartment.
Push the button to pop up the flash.
Remove one 3.5 mm #00 screw.
Remove one 5.5 mm #00 screw.
Carefully lift the top cover away from the body to access wired connections.
Peel back the corner of the rubber grip.
Remove the small plastic cover.
Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
Desolder the red wire.
Carefully lift the sides of the white latch.
Desolder blue, black, brown and green wires.
Remove the loose shim washer if present.
Remove the piece of cellophane tape covering the flex connections.
Desolder flex connetions.
