Ga door naar hoofdinhoud
Top Cover Removal
Wat je nodig hebt
  1. Top Cover Removal, Remove film door: stap 1, afbeelding 1 van 1
    • Push down the latch to release the film door.
  2. Top Cover Removal, Remove top cover screws: stap 2, afbeelding 1 van 3 Top Cover Removal, Remove top cover screws: stap 2, afbeelding 2 van 3 Top Cover Removal, Remove top cover screws: stap 2, afbeelding 3 van 3
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
  3. Top Cover Removal, Remove top cover screws: stap 3, afbeelding 1 van 3 Top Cover Removal, Remove top cover screws: stap 3, afbeelding 2 van 3 Top Cover Removal, Remove top cover screws: stap 3, afbeelding 3 van 3
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
  4. Top Cover Removal, Lift top cover: stap 4, afbeelding 1 van 1
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
  5. Top Cover Removal, Access flash connections: stap 5, afbeelding 1 van 2 Top Cover Removal, Access flash connections: stap 5, afbeelding 2 van 2
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
  6. Top Cover Removal, Discharge flash capacitors: stap 6, afbeelding 1 van 1
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  7. Top Cover Removal, Disconnect right flex cable: stap 7, afbeelding 1 van 1
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
  8. Top Cover Removal, Disconnect left flex cable: stap 8, afbeelding 1 van 1
    • Desolder the red wire.
  9. Top Cover Removal, Desolder flash connections: stap 9, afbeelding 1 van 2 Top Cover Removal, Desolder flash connections: stap 9, afbeelding 2 van 2
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
  10. Top Cover Removal, Desolder the flash flex cable: stap 10, afbeelding 1 van 2 Top Cover Removal, Desolder the flash flex cable: stap 10, afbeelding 2 van 2
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
Conclusie
Sam Gustafson
10.623 Reputatie
57 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 414
