Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
Unscrew the two T5 screws using the T5 Torx Screwdriver.
Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
Reattach the yellow ribbon cable to the motherboard.
Using two hands, hold both ends of the device and snap the two plates together.
Re-apply the label edges back down to cover the screws.
3 andere personen hebben deze handleiding voltooid.
