Ga door naar hoofdinhoud
  1. Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
    • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  2. Unscrew the two T5 screws using the T5 Torx Screwdriver.
    • Unscrew the two T5 screws using the T5 Torx Screwdriver.
  3. Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
    • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  4. Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
    • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  5. Remove the screen from of the face-plate.
    • Remove the screen from of the face-plate.
  6. Insert the new screen into the face-plate.
    • Insert the new screen into the face-plate.
  7. Reattach the yellow ribbon cable to the motherboard.
    • Reattach the yellow ribbon cable to the motherboard.
  8. Using two hands, hold both ends of the device and snap the two plates together.
    • Using two hands, hold both ends of the device and snap the two plates together.
  9. Re-insert the two T5 screws and tighten.
    • Re-insert the two T5 screws and tighten.
  10. Re-apply the label edges back down to cover the screws.
    • Re-apply the label edges back down to cover the screws.
Conclusie
Mike Sollars
507 Reputatie
3 handleidingen geschreven
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Leden
6 handleidingen geschreven
Één commentaar
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,559
