Ga door naar hoofdinhoud
TomTom XL Screen and Motherboard Replacement
Wat je nodig hebt
  1. TomTom XL Screen and Motherboard Replacement, Screen and Motherboard: stap 1, afbeelding 1 van 1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Screen and Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Screen and Motherboard Replacement: stap 3, afbeelding 1 van 3 TomTom XL Screen and Motherboard Replacement: stap 3, afbeelding 2 van 3 TomTom XL Screen and Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Screen and Motherboard Replacement: stap 4, afbeelding 1 van 2 TomTom XL Screen and Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Screen and Motherboard Replacement: stap 5, afbeelding 1 van 2 TomTom XL Screen and Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Screen and Motherboard Replacement: stap 6, afbeelding 1 van 2 TomTom XL Screen and Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adam Johnson
122 Reputatie
2 handleidingen geschreven
Cal Poly, Team 33-84, Johann Spring 2010 Lid van Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 14
Altijd: 9,042
