Inleiding
Use this guide to remove or replace the screen in the TomTom XL.
Wat je nodig hebt
Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
Starting at the corners, carefully pry up the screen bezel.
Using your thumbs or the flat end of a spudger, push back the white tabs on the display cable ZIF connector.
Gently pull the orange display cable out of the ZIF connector.
Bijna klaar!
Conclusie
