Inleiding
GPS may be dropped and the front screen is cracked. Replacement is needed in order to properly see the screen and avoid getting cut from broken glass. When prying do not use metal tool as this can cause static damage. Be careful when removing the screen because the broken glass can cut you. The device can be identified by it's model number which is located under the small panel on the bottom of the device.
Wat je nodig hebt
Locate the round suction cup on the back of the device.
Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
To reassemble your device, follow these instructions in reverse order. Now you're done and your device is ready to use!
