Ga door naar hoofdinhoud
TomTom VIA 1605TM Back Cover Replacement
Wat je nodig hebt
  1. TomTom VIA 1605TM Back Cover Replacement, Front Screen: stap 1, afbeelding 1 van 3 TomTom VIA 1605TM Back Cover Replacement, Front Screen: stap 1, afbeelding 2 van 3 TomTom VIA 1605TM Back Cover Replacement, Front Screen: stap 1, afbeelding 3 van 3
    • Locate the round suction cup on the back of the device.
    • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
    • When reassembling twist the suction cup but, push in as oppose to pulling out.
  2. TomTom VIA 1605TM Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Location of screw is where the suction cup was.
    • Insert 8mm Hex #T6 screw driver into screw.
    • Unscrew in counter clockwise direction.
    • When reassembling screw in the clockwise direction.
  3. TomTom VIA 1605TM Back Cover Replacement: stap 3, afbeelding 1 van 2 TomTom VIA 1605TM Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Pry along the edges with the plastic opening tool to separate the back and front panel.
    • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
  4. TomTom VIA 1605TM Back Cover Replacement: stap 4, afbeelding 1 van 3 TomTom VIA 1605TM Back Cover Replacement: stap 4, afbeelding 2 van 3 TomTom VIA 1605TM Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
    • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
  5. TomTom VIA 1605TM Back Cover Replacement, Motherboard: stap 5, afbeelding 1 van 3 TomTom VIA 1605TM Back Cover Replacement, Motherboard: stap 5, afbeelding 2 van 3 TomTom VIA 1605TM Back Cover Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard.
    • Unscrew each of these in a counter clockwise direction.
    • When reassembling screw back in a clockwise direction.
    • The second picture is to represent where the four screws are located. The LCD screen does not disconnect from the motherboard until the next step.
  6. TomTom VIA 1605TM Back Cover Replacement: stap 6, afbeelding 1 van 3 TomTom VIA 1605TM Back Cover Replacement: stap 6, afbeelding 2 van 3 TomTom VIA 1605TM Back Cover Replacement: stap 6, afbeelding 3 van 3
    • Remove the Blue Ribbon Cable by pushing each side of the plastic holder with the nylon spudger.
    • This will remove the LCD screen from the motherboard.
  7. TomTom VIA 1605TM Back Cover Replacement: stap 7, afbeelding 1 van 1
    • Unplug the wire connecting to the speaker by pinching the sides connected to the back screen.
    • Pull back away (in the opposite direction) from the connector.
    • When reassembling push back into connector. Do not need to pinch anything. The "click" sound ensures solid connection.
  8. TomTom VIA 1605TM Back Cover Replacement: stap 8, afbeelding 1 van 2 TomTom VIA 1605TM Back Cover Replacement: stap 8, afbeelding 2 van 2
    • Unplug the battery, the same way we unplugged the speaker by pinching the sides of the connection.
    • Pull away from the connector
  9. TomTom VIA 1605TM Back Cover Replacement: stap 9, afbeelding 1 van 1
    • Properly dispose of the old motherboard. Replace with the new motherboard.
    • Skip this step(i.e. do not dispose of motherboard) if this part of prerequisite guide for the back cover replacement.
  10. TomTom VIA 1605TM Back Cover Replacement, Back Cover: stap 10, afbeelding 1 van 1
    • Replace the back cover screen, now that all parts have been properly removed.
Conclusie
Tyler Wade
362 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-4, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-4, Catania Fall 2015
UMASSD-CATANIA-F15S4G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 647
