Ga door naar hoofdinhoud
TomTom VIA 1530 TM Motherboard Replacement
Wat je nodig hebt
  1. TomTom VIA 1530 TM Motherboard Replacement, Back: stap 1, afbeelding 1 van 2 TomTom VIA 1530 TM Motherboard Replacement, Back: stap 1, afbeelding 2 van 2
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
  2. TomTom VIA 1530 TM Motherboard Replacement: stap 2, afbeelding 1 van 2 TomTom VIA 1530 TM Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  3. TomTom VIA 1530 TM Motherboard Replacement: stap 3, afbeelding 1 van 2 TomTom VIA 1530 TM Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
  4. TomTom VIA 1530 TM Motherboard Replacement: stap 4, afbeelding 1 van 2 TomTom VIA 1530 TM Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
  5. TomTom VIA 1530 TM Motherboard Replacement: stap 5, afbeelding 1 van 3 TomTom VIA 1530 TM Motherboard Replacement: stap 5, afbeelding 2 van 3 TomTom VIA 1530 TM Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
  6. TomTom VIA 1530 TM Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 TomTom VIA 1530 TM Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
    • Slide the gold ribbon cable out of the port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jennifer Zakaria
555 Reputatie
6 handleidingen geschreven
Cal Poly, Team S12-G2, Banghart Winter 2018 Lid van Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 322
