Ga door naar hoofdinhoud
TomTom One XL Battery Replacement
Wat je nodig hebt
  1. TomTom One XL Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 TomTom One XL Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: stap 2, afbeelding 1 van 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: stap 3, afbeelding 1 van 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: stap 4, afbeelding 1 van 2 TomTom One XL Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: stap 6, afbeelding 1 van 3 TomTom One XL Battery Replacement: stap 6, afbeelding 2 van 3 TomTom One XL Battery Replacement: stap 6, afbeelding 3 van 3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: stap 7, afbeelding 1 van 3 TomTom One XL Battery Replacement: stap 7, afbeelding 2 van 3 TomTom One XL Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: stap 8, afbeelding 1 van 3 TomTom One XL Battery Replacement: stap 8, afbeelding 2 van 3 TomTom One XL Battery Replacement: stap 8, afbeelding 3 van 3
    • Reconnect the battery ribbon cable to its port.
Conclusie
DeVhan
401 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 9-6, Panko Spring 2015 Lid van Colorado Springs, Team 9-6, Panko Spring 2015
UCCS-PANKO-S15S9G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,476
