Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
As you can see, the battery and the speaker are still attached to the device and must be removed.
Using the spudger, carefully pry out both the battery and the speaker.
Once the battery and the speaker are removed, you now only have the back cover!
