Inleiding
The back cover on the TomTom ONE is likely to chip or break due to excessive use. The mount guides can get worn down and not function properly. This guide will help you to replace it.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
