Ga door naar hoofdinhoud
TomTom GO 500 Display or Digitizer Replacement
Wat je nodig hebt
  1. TomTom GO 500 Display or Digitizer Replacement, TomTom GO 500 Opening the Device: stap 1, afbeelding 1 van 1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
    Vraag FixBot
  2. TomTom GO 500 Display or Digitizer Replacement: stap 2, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
    Vraag FixBot
  3. TomTom GO 500 Display or Digitizer Replacement: stap 3, afbeelding 1 van 1
    • With the screen casing unlatched, locate the right side where the two connectors are.
    Vraag FixBot
  4. TomTom GO 500 Display or Digitizer Replacement: stap 4, afbeelding 1 van 3 TomTom GO 500 Display or Digitizer Replacement: stap 4, afbeelding 2 van 3 TomTom GO 500 Display or Digitizer Replacement: stap 4, afbeelding 3 van 3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
    Vraag FixBot
  5. TomTom GO 500 Display or Digitizer Replacement: stap 5, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement: stap 5, afbeelding 2 van 2
    • Separate the screen casing from the motherboard casing.
    Vraag FixBot
  6. TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: stap 6, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the microphone on the left side of the screen casing using tweezers.
    • Use tweezers with rounded tips to avoid damaging the microphone.
    Vraag FixBot
  7. TomTom GO 500 Display or Digitizer Replacement: stap 7, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement: stap 7, afbeelding 2 van 2
    • Lift up the small black tab on the orange connector using a plastic opening tool. This releases the strip connecting the display to the digitizer.
    Vraag FixBot
  8. TomTom GO 500 Display or Digitizer Replacement: stap 8, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement: stap 8, afbeelding 2 van 2
    • Slide the connector strip out from the tab.
    Vraag FixBot
  9. TomTom GO 500 Display or Digitizer Replacement: stap 9, afbeelding 1 van 2 TomTom GO 500 Display or Digitizer Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the eight 2.5mm screws along the perimeter of the display using the Phillips #000 screwdriver.
    Vraag FixBot
  10. TomTom GO 500 Display or Digitizer Replacement: stap 10, afbeelding 1 van 3 TomTom GO 500 Display or Digitizer Replacement: stap 10, afbeelding 2 van 3 TomTom GO 500 Display or Digitizer Replacement: stap 10, afbeelding 3 van 3
    • Separate the display from the digitizer. The display is now fully removed from the device.
    Vraag FixBot
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jennie Chang
173 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-5, Oliver Fall 2016 Lid van UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Leden
9 handleidingen geschreven
3Gids Commentaar
If you keep the bezel and replace the glass, ensure the glass has adhesive before you buy.
Aaron - Antwoord Deel
Do you have branch in Istanbul?
if yes please provide me the address. thaxs
Bsssam Kabeir - Antwoord Deel
pertituire schermo e display cosa devo fare e comprare grazie
Cesare - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 82
Altijd: 7,285
