Ga door naar hoofdinhoud
TomTom GO 500 Battery Replacement
Wat je nodig hebt
  1. TomTom GO 500 Battery Replacement, TomTom GO 500 Opening the Device: stap 1, afbeelding 1 van 1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Battery Replacement: stap 2, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Battery Replacement: stap 3, afbeelding 1 van 1
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Battery Replacement: stap 4, afbeelding 1 van 3 TomTom GO 500 Battery Replacement: stap 4, afbeelding 2 van 3 TomTom GO 500 Battery Replacement: stap 4, afbeelding 3 van 3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Battery Replacement: stap 5, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 5, afbeelding 2 van 2
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Battery Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. TomTom GO 500 Battery Replacement: stap 7, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 7, afbeelding 2 van 2
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. TomTom GO 500 Battery Replacement: stap 8, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 8, afbeelding 2 van 2
    • Unplug the second connector using the plastic opening tool.
  9. TomTom GO 500 Battery Replacement: stap 9, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the motherboard from the casing.
  10. TomTom GO 500 Battery Replacement, Battery: stap 10, afbeelding 1 van 1
    • After opening the device and removing the motherboard, you will see the battery attached to the frame.
  11. TomTom GO 500 Battery Replacement: stap 11, afbeelding 1 van 2 TomTom GO 500 Battery Replacement: stap 11, afbeelding 2 van 2
    • Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame.
    • The battery attaches to the frame with double-sided tape so this should be fairly easy to remove.
    • In this image, a smaller plastic tool was used on the left side while a larger one was used on the right side.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Oriana Hone
321 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-5, Oliver Fall 2016 Lid van UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Leden
9 handleidingen geschreven
5 opmerkingen
Very effective guide, easy to follow and good images too, thank you Mike
Mike Jones - Antwoord
Most difficult part was opening the case, seemed to work best with the opening tool ends pointed down (screen up), levered the latches best.
Reassembling, the larger of the two connections that attach the screen to the motherboard case was fiddly to line up, it requires a bit of care and patience.
Thanks for these instructions.
Alan - Antwoord
Danke, Oriana Hone (und 3 anderen Mitwirkenden), gute Anleitung.
Und ja, wie vorgewarnt, 4 der Plastik-Verriegelungen brachen leicht während des Öffnungsvorgangs. Jetzt muss ich wohl ein neues Bildschirmgehäuse finden... Oder genügen die verbleibenden 10?
vjrott - Antwoord
Thanks, Oriana Hone (and 3 other contributors), good guide. Used it for GO 5000.
And yes, as forewarned, 4 of the plastic latches broke easily during the opening process. Now I guess I'll have to find a new screen casing... Or will the remaining suffice?
vjrott - Antwoord
tip top - alles bestens erklärt. Geduld haben, vorsichtig sein,
Ich hatte den neuen Akku zusammen mit einem Set Spezialwerkzeug online bestellt; damit ging es wirklich super.
Ron Tyler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 179
Altijd: 11,551
