Ga door naar hoofdinhoud
Toilet Tank Assembly Replacement
Wat je nodig hebt
  1. Toilet Tank Assembly Replacement, Tank Lid: stap 1, afbeelding 1 van 3 Toilet Tank Assembly Replacement, Tank Lid: stap 1, afbeelding 2 van 3 Toilet Tank Assembly Replacement, Tank Lid: stap 1, afbeelding 3 van 3
    • Lift the tank lid up and away from the toilet tank.
    Vraag FixBot
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: stap 2, afbeelding 1 van 2 Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: stap 2, afbeelding 2 van 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
    Vraag FixBot
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: stap 3, afbeelding 1 van 2 Toilet Tank Assembly Replacement, Draining a Toilet Tank: stap 3, afbeelding 2 van 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
    Vraag FixBot
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: stap 4, afbeelding 1 van 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: stap 4, afbeelding 2 van 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: stap 4, afbeelding 3 van 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    Vraag FixBot
  5. Toilet Tank Assembly Replacement, Supply Tube: stap 5, afbeelding 1 van 3 Toilet Tank Assembly Replacement, Supply Tube: stap 5, afbeelding 2 van 3 Toilet Tank Assembly Replacement, Supply Tube: stap 5, afbeelding 3 van 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
    Vraag FixBot
  6. Toilet Tank Assembly Replacement, Tank Assembly: stap 6, afbeelding 1 van 3 Toilet Tank Assembly Replacement, Tank Assembly: stap 6, afbeelding 2 van 3 Toilet Tank Assembly Replacement, Tank Assembly: stap 6, afbeelding 3 van 3
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
    Vraag FixBot
  7. Toilet Tank Assembly Replacement: stap 7, afbeelding 1 van 2 Toilet Tank Assembly Replacement: stap 7, afbeelding 2 van 2
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
    Vraag FixBot
Conclusie
11 andere personen hebben deze handleiding voltooid.
Ron Davis
33.473 Reputatie
13 handleidingen geschreven
3Gids Commentaar
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Antwoord Deel
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Antwoord Deel
Thank you for the info.
DonnaRHellman - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 255
Altijd: 18,276
