Ga door naar hoofdinhoud
Toilet Keeps Running: How to Fix & Maintain Valve Seat
Wat je nodig hebt
  1. Toilet Keeps Running: How to Fix & Maintain Valve Seat, Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 1, afbeelding 1 van 1
    • Remove the lid from the toilet tank.
  2. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 2, afbeelding 1 van 1
    • Flush the toilet, and hold down the flush lever until the tank is completely empty.
  3. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 3, afbeelding 1 van 1
    • Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
  4. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 4, afbeelding 1 van 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 4, afbeelding 2 van 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 4, afbeelding 3 van 3
    • Pull up the valve seat. If possible, keep it raised without releasing the float.
    • If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
    • Some toilets may use a float ball to control overflow.
  5. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 5, afbeelding 1 van 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 5, afbeelding 2 van 2
    • Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
  6. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 6, afbeelding 1 van 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 6, afbeelding 2 van 2
    • Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
  7. Toilet Keeps Running: How to Fix & Maintain Valve Seat: stap 7, afbeelding 1 van 1
    • Place the lid back on the tank.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Roman Snow
169 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G37, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G37, Cardinal Spring 2020
UWT-CARDINAL-S20S1G37
1 Lid
1 handleiding geschreven
3 opmerkingen
Cutting off the water supply, draining the tank and spraying the seat with vinegar or CLR does the same thing -dissolving the calcium carbonate. You can prevent calcium carbonate buildup by putting a piece of magnesium in the tank.
P Schmied - Antwoord
Thanks for Step #7. Always forget that one!
Matt Heckel - Antwoord
You may use a calcium remover for toilets. If you have patience and willingness, you can make a DIY toilet cleaner composed of vinegar, lemon, other acidic liquids, and baking soda. Thick calcium deposits in the toilet require muriatic acid and deep scrubbing with scour paper.
lim anna - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 57
Altijd: 820
