Ga door naar hoofdinhoud
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: stap 1, afbeelding 1 van 3 Toilet Flapper Replacement, Tank Lid: stap 1, afbeelding 2 van 3 Toilet Flapper Replacement, Tank Lid: stap 1, afbeelding 3 van 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: stap 2, afbeelding 1 van 2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: stap 2, afbeelding 2 van 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: stap 3, afbeelding 1 van 2 Toilet Flapper Replacement, Draining a Toilet Tank: stap 3, afbeelding 2 van 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: stap 4, afbeelding 1 van 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: stap 4, afbeelding 2 van 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: stap 4, afbeelding 3 van 3
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: stap 5, afbeelding 1 van 3 Toilet Flapper Replacement, Flapper: stap 5, afbeelding 2 van 3 Toilet Flapper Replacement, Flapper: stap 5, afbeelding 3 van 3
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kristen Gismondi
106.043 Reputatie
267 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.685 handleidingen geschreven
2Gids Commentaar
Thank you I needed that
My Mama - Antwoord Deel
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 73
Afgelopen 30 dagen: 327
Altijd: 18,147
