Ga door naar hoofdinhoud
Toguard C200 Battery Replacement
Wat je nodig hebt
  1. Toguard C200 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Toguard C200 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a suction handle to remove the screen from the camera.
  2. Toguard C200 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to pry off the bezel.
  3. Toguard C200 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to unscrew the 4 screws to access the battery underneath.
    • Lift the motherboard slightly.
    • Make sure to keep all the screws together to not misplace any of them.
  4. Toguard C200 Battery Replacement: stap 4, afbeelding 1 van 2 Toguard C200 Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers and your hands to remove the battery from its original place.
  5. Toguard C200 Battery Replacement: stap 5, afbeelding 1 van 1
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery
    • Desolder the old battery.
    • Heat the solder by using the soldering iron until it starts to melt. Try nudging the pins with the soldering iron to move the solder away from the joints. Pull the components you want to remove with the pliers.
    • Solder the new battery and make sure the + and - wires correctly match the motherboard. (Any super capacitor of 200mAh or higher will work)
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hema T
295 Reputatie
1 Handleiding geschreven
Één opmerking
GENIAL! muchas gracias
mfsilvam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 149
