Inleiding
Use this guide to replace the pressure adjustment assembly in your Titan Impact 410 Airless Sprayer.
Wat je nodig hebt
Use a Phillips driver to remove the four 12 mm-long screws securing the motor controller assembly.
Pull the motor controller assembly out and hold it to the side, exposing the cables.
Use a pair of needle nose pliers, or your fingers, to disconnect the two spade connectors from to the on/off switch.
Disconnect the one spade connector on the circuit breaker.
Use your fingers to unscrew and remove the circuit breaker nut.
Remove the circuit breaker.
Use a flathead screwdriver to depress the locking tabs located on both the top and bottom of the on/off switch.
While depressing the tabs, push the on/off switch out through the cutout.
Remove the on/off switch.
Use a Phillips driver to remove the two 17 mm-long screws securing the contact switch.
Pull the contact switch away from the plunger and place it on the floor of the housing.
Use snap ring pliers to remove the retaining ring from the top of the plunger.
Loosen the pressure control knob.
Remove the pressure control knob.
Één andere persoon heeft deze handleiding voltooid.
