Ga door naar hoofdinhoud
Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement
Wat je nodig hebt
  1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: stap 1, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: stap 1, afbeelding 2 van 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: stap 2, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: stap 2, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: stap 2, afbeelding 3 van 3
    • Use a flat punch tool and a hammer to tap the groove pin from left to right out of the valve handle.
  3. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: stap 3, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the valve handle from the cam base.
    • During reassembly, apply grease to the cam base before reattaching the valve handle.
  4. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: stap 4, afbeelding 1 van 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: stap 4, afbeelding 2 van 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: stap 4, afbeelding 3 van 3
    • Remove the cam base.
  5. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: stap 5, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: stap 5, afbeelding 2 van 2
    • Use a 13/16" wrench, or an adjustable wrench, to loosen the bypass valve assembly.
    • Rotate the wrench counterclockwise.
  6. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: stap 6, afbeelding 1 van 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: stap 6, afbeelding 2 van 2
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Diaz-Kokaisl
125.789 Reputatie
592 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.524 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 501
