Inleiding
The Tineco FLOOR ONE S3 Breeze (model no. FW007600US) will sometimes have problems with the brush motor wearing out over time, and it may need to be replaced by removing the wheel cover plate and removing the existing motor. After a quick reassembly the machine is ready to operate. This replacement guide contains the following steps for the wheels replacement.
The brush motor allows the brush roller to operate and clean floors properly. Without the brush motor, the cleaner would not be able to complete it functions.
The first two steps of the wheel replacement guide is being used, but the third step is skipped for the brush motor replacement.
Wat je nodig hebt
Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
Remove the first plastic cover.
