Ga door naar hoofdinhoud
Timex W-10 Children's Watch Battery Replacement
Wat je nodig hebt
  1. Timex W-10 Children's Watch Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Timex W-10 Children's Watch Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Timex W-10 Children's Watch Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: stap 2, afbeelding 1 van 2 Timex W-10 Children's Watch Battery Replacement: stap 2, afbeelding 2 van 2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: stap 3, afbeelding 1 van 2 Timex W-10 Children's Watch Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: stap 4, afbeelding 1 van 2 Timex W-10 Children's Watch Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: stap 5, afbeelding 1 van 2 Timex W-10 Children's Watch Battery Replacement: stap 5, afbeelding 2 van 2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tarik Ihmoud
128 Reputatie
1 Handleiding geschreven
2 opmerkingen
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Antwoord
Daniel Melendrez - June 12
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 80
Altijd: 8,093
