Inleiding
The guide shows how to replace the relay (transformer) in a timer switch. This transformer is used for heater control. Without this transformer, the switch does not work.
The timer switch was bought at Gamma (link), a large construction store.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Desoldering Pump$3.99
Melt the solder with the soldering iron.
Use the desoldering pump to suck up the old solder.
Pull the relay from the PCB.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Very nice instruction, also for maintaining gardening equipment as a robotic lawnmower.
