Wat je nodig hebt
Here are the tools you will need:
A new roller wheel & hub piece.
Standard screwdriver.
4mm Allen wrench.
Using Allen wrench, unscrew axle bolts from the inside of the luggage backing.
Be careful not to let the inside screw fall into the inside roller tubing during the entirety of this procedure. We advise going slowly. Under no circumstances should this be performed with the damaged/missing wheel facing up.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Thanks, Emilee!
note also that if it is only the wheel itself that is damaged, you can unscrew the wheel from its plastic housing and replace it without detaching the handle.
Does anyone know of a 3rd party wheel that works as a drop-in replacement? The manufacturer does not have stock and I have a trip planned!
