Ga door naar hoofdinhoud
Tightening Mt. Fury Roadmaster Brake Cables
Wat je nodig hebt
  1. Tightening Mt. Fury Roadmaster Brake Cables, Tightening Mt. Fury Roadmaster Brake Cables: stap 1, afbeelding 1 van 1
    • Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
  2. Tightening Mt. Fury Roadmaster Brake Cables: stap 2, afbeelding 1 van 1
    • Pull the brake cable until proper tension is acquired and the cable shows resistance.
  3. Tightening Mt. Fury Roadmaster Brake Cables: stap 3, afbeelding 1 van 1
    • Re-tighten the clamping nut.
  4. Tightening Mt. Fury Roadmaster Brake Cables: stap 4, afbeelding 1 van 1
    • If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
  5. Tightening Mt. Fury Roadmaster Brake Cables: stap 5, afbeelding 1 van 1
    • For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
Conclusie
Your brakes should be fully tightened now.
11 andere personen hebben deze handleiding voltooid.
Samantha Rawlins
476 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-40, Maness Winter 2014 Lid van Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Leden
5 handleidingen geschreven
Één opmerking
Thank God I didn’t have to watch someone's long winded 10 minute video explaining this.  lol Thank you for that!  Great article.  Thanks for helping me out!
rtinmotion - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 3,311
