Ga door naar hoofdinhoud
TiVo Series 2 TCD540080 Power Supply Replacement
Wat je nodig hebt
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: stap 1, afbeelding 1 van 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: stap 2, afbeelding 1 van 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: stap 3, afbeelding 1 van 2 TiVo Series 2 TCD540080 Power Supply Replacement: stap 3, afbeelding 2 van 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: stap 4, afbeelding 1 van 2 TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: stap 4, afbeelding 2 van 2
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: stap 6, afbeelding 1 van 1
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: stap 7, afbeelding 1 van 2 TiVo Series 2 TCD540080 Power Supply Replacement: stap 7, afbeelding 2 van 2
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: stap 8, afbeelding 1 van 2 TiVo Series 2 TCD540080 Power Supply Replacement: stap 8, afbeelding 2 van 2
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
Conclusie
Svyatoslav Markeyev
135 Reputatie
5 handleidingen geschreven
Cal Poly, Team 33-79, Johann Spring 2010 Lid van Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 5,198
