Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Power down the TiVo and detach the power cable from the rear of the unit.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. Remove the five T10 screws from the rear of the case using the Torx screwdriver.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
    • Lift up and pull back the outer casing towards the rear of the unit.
  5. The fan is held in by four T15 screws on the rear of the device.
    • The fan is held in by four T15 screws on the rear of the device.
  6. Take the wound red and black wires coming from the fan and follow them back to the logic board. Unplug the connector from the motherboard.
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  7. Pull the fan towards the front and out of the TiVo unit. Pull the fan towards the front and out of the TiVo unit.
    • Pull the fan towards the front and out of the TiVo unit.
Conclusie
Svyatoslav Markeyev
135 Reputatie
5 handleidingen geschreven
Cal Poly, Team 33-79, Johann Spring 2010 Lid van Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 5,078
