Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the five 0.31 inch T-9 screws on the back cover.
Slide the cover towards the back until it is no longer under the front cover.
Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
Unscrew the two 0.31 inch T-9 screws on the inside of the front cover.
Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
Unscrew the two 0.31 inch T-9 screws on the back of the sensor.
