Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The power supply allows for the TiVo components to work. In the situation that it needs to be replaced, this guide will walk you through the installation of the power supply
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Locate the power supply.
    • Locate the power supply.
  6. Remove the belt connecting the power supply to the motherboard by pulling it out.
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  7. Remove the red, yellow, and black cable connecting the power supply to the hard drive.
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  8. Remove the two 0.31 inch T-9 screws from the power supply.
    • Remove the two 0.31 inch T-9 screws from the power supply.
  9. Pinch the plastic plugs and lift the power supply up to detach from plugs. All 4 plugs must be detached to remove power supply.
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Conclusie
Phil Jones
41 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-33, Amido Fall 2011 Lid van Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,086
