Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the five 0.31 inch T-9 screws on the back cover.
Slide the cover towards the back until it is no longer under the front cover.
Unscrew the 0.31 inch T-9 size screw on the back panel
Unscrew the two 0.59 inch T-8 size screws on the back panel
Unplug the fan from the motherboard by gently pulling up on the red plug.
Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
Locate the four metal tabs on the motherboard.
Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
Pull directly up on the motherboard so that it slips over the four golden metal tabs.
Pull up and away from the back panel so all of the cable inputs slip through the casing.
