Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide describes how to replace the hard drive.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. Locate the hard drive.
    • Locate the hard drive.
  5. Remove the ribbon cable by applying firm pressure to the black tabs on the sides. Remove the power cable to the right of the ribbon cable.
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  6. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove. Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
Conclusie
Talha
31 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-33, Amido Fall 2011 Lid van Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,573
