Inleiding
The motherboard keeps all function intact, whether start ups or shut downs, the motherboard sends the desired signal that you wish. If buttons do not work properly and send the correct signals, then the motherboard may be the problem and here is how to replace it.
Wat je nodig hebt
Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
Remove the single 140 mm T8 screw from the back panel using a Torx screwdriver.
