Ga door naar hoofdinhoud
Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
Wat je nodig hebt
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: stap 2, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mohammed Alsogair
339 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G33, Cagle Fall 2017 Lid van USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Leden
5 handleidingen geschreven
3 opmerkingen
how can I replace elastic cord?
geoff - Antwoord
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - Antwoord
Where did you get a replacement motherboard?
Paul Stewart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 103
Altijd: 5,327
