Ga door naar hoofdinhoud
Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement
Wat je nodig hebt
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: stap 2, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: stap 3, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: stap 3, afbeelding 2 van 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
Conclusie
Mario Nunez
421 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G33, Cagle Fall 2017 Lid van USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Leden
5 handleidingen geschreven
2 opmerkingen
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - Antwoord
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 48
Altijd: 5,474
