Ga door naar hoofdinhoud
Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement
Wat je nodig hebt
  1. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: stap 2, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: stap 3, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: stap 3, afbeelding 2 van 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
  4. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: stap 4, afbeelding 1 van 2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: stap 4, afbeelding 2 van 2
    • Desolder the black cable that connects the USB port to the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Mario Nunez
421 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G33, Cagle Fall 2017 Lid van USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 Leden
5 handleidingen geschreven
7 opmerkingen
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Rene Haeren - Antwoord
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Malcolm Clenton - Antwoord
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
lilybaxter505 - Antwoord
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
Hez van der Meij -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 71
Altijd: 8,918
